Discussion topic: Connection problems with one box
This message was authored by: Gazinho99
I have 2 sky boxes. I disconnected one but when I reconnected it, it would not pick up the sky box beyond the first page saying it was booting up.
Re: Connection problems with one box
Hi @Gazinho99
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button.  You can also use the connected mini for WPS if it is the nearest.
