Discussion topic: Remote and Apps not working
This message was authored by: Kev1nK
my SkyQ apps are not working and my TV remote is also not working
Re: Remote and Apps not working
Hi @Kev1nK
Try completly resetting your Bluetooth remote.
Regarding the Apps in what way are they not working?
If you are not connected to the Internet the Apps and On Demand will not work.  If this is the case
