Discussion topic: Connection help
This message was authored by: Cwmbowydd
Connection help
Ive changed my broadband provider from Sky but my tv wont connect
Re: Connection help
Hi @Cwmbowydd
Carry out a Network reset on your Q box.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
