7
This discussion topic has been answered Discussion topic: BBC South West
This message was authored by: Galanthus
BBC South West
In the last couple of days Channel 967 is unavailable through our Sky Q box. BBC West is classed as our local channel and takes the channel 101 slot but I prefer the coverage and news BBC South West provides. Anyone know why it has disappeared? I have tried a reboot and software update of the box to no avail.
Help!
Avatar for Galanthus
This message was authored by: Galanthus Answer
Re: BBC South West
Thanks! Scrolling through BBC South West had changed from channel 967 to channel 962!
Problem solved 👍
Re: BBC South West
Help!
@Galanthus gthere was a change to some of the channel numbers try 960 for BBC1 South West HD if not try looking from 951 upwards
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: BBC South West
I can get BBC West, it's BBC South West that has disappeared
Re: BBC South West
@Galanthus I amended my post as I entered West instead of south West  as I get south west on 101 so got them mixed up as I said try 960 for BBC South West
Re: BBC South West
Problem solved 👍
This message was authored by: Sheetbag
Re: BBC South West
As a BBC southwest viewer, I can't say I've noticed any issues, but it's my regional channel.
I can't check right now, cos the Mrs will slap me for her missing repair shop!
It's certainly broadcasting fine as my regional channel.
Mac
Re: BBC South West
UPDATE
just checked, and it says, channel unavailable.
Now, I don't know if that's cos I live in the region, or cos it's some other issue.
Mac
Re: BBC South West
It's changed to channel 962
