12 Apr 2023 08:58 PM
Ive changed my broadband provider from Sky but my tv wont connect
12 Apr 2023 09:01 PM
Hi @Cwmbowydd
Carry out a Network reset on your Q box.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
