Discussion topic: Connection between mini box and sky q box keeps dropping
This message was authored by: Hdot
Re: Connection between mini box and sky q box keeps dropping
Hi @Hdot
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
If your issue continues you may need a Q WiFi booster positioned midway between the main box and the mini.
Avatar for Hdot
Tried all of those before I posted. However 5 minutes after I posted it, it sorted itself!
Thanks though. Good to know I was doing the right things
