2
This discussion topic has been answered Discussion topic: Connecting sky mini box
This message was authored by: AWJW
I've just bought a new tv and the hdmi ports are on the opposite side from my previous tv meaning that my sky mini box hdmi cable will not reach. Do I have to use the official sky cable that the box came with or can I use any longer hdmi cable?
This message was authored by: nigea99 Answer
Re: Connecting sky mini box
hi @AWJW
You can use  virtually any HDMI cable , which you can get from many outlets
(HDMI 1.4 or above & able to support HDCP 1.4  or above for use with mini boxes  - which is probably virtually all that are available these days  - 4K , which minis don't support, need higher versions- HDMI 2.0 or higher  & HDCP 2.2)
Edit : Note you do not need to spend silly amounts that some well known stores charge
hi @AWJW
Avatar for AWJW
Hi @nigea99
Thank you for your reply. I was always told to use the official cable, assuming this was to ensure it covers the correct specifications so I appreciate your help with this.
