Discussion topic: Connect
Message posted on 09 Jan 2024 07:15 PM
Connect
You cannot watch Tv at the moment as there is a connectivity problem
Message posted on 09 Jan 2024 07:29 PM
Re: Connect
Hi @Ballybee
Is this on your main Q box or a Mini box?
If main Q box
Settings changed within the hidden engineer menu, include LNB type. If on a communal dish you need to reset the LNB to SCR in the hidden menu. After changing the LNB type you need to reboot the Q boot it is a mini box
Reboot the mini as above.
