Discussion topic: 5 days with black screens
Message posted on 09 Jan 2024 07:24 PM
Hi - for 5 days I have had black screens on my may SkyQ and SkyQmini boxes.
if I do a full reboot on the main skyQ box I get back channels/signal for about 2 hours - but the picture cuts out to a black screen every 10 mins for about 5 seconds. When the picture comes back on I am able to rewind and watch the missing 5 seconds. Then after 2 hours or so (or when I change channel) I get black screens again.
when checking settings the network is connected on all devices and the satellite signal is strong on the main SkyQ box so I am unsure what the issue is that is causing this.
Message posted on 09 Jan 2024 07:27 PM
Re: 5 days with black screens
if I do a full reboot on the main skyQ box I get back channels/signal for about 2 hours - but the picture cuts out to a black screen every 10 mins for about 5 seconds. When the picture comes back on I am able to rewind and watch the missing 5 seconds. Then after 2 hours or so (or when I change channel) I get black screens again.when checking settings the network is connected on all devices and the satellite signal is strong on the main SkyQ box so I am unsure what the issue is that is causing this.
Hi @JockoJ
First try a Reset Settings in the main Q box hidden menu.
