Discussion topic: Subtitles stalling when in use
This message was authored by: Tonytim
When watching programmes using subtitles they work for a tim and then stall and then restart but stall again. Very frustrating and annoying
Re: Subtitles stalling when in use
Hi @Tonytim
Try a Reset Settings in the main Q box hidden menu.
