Discussion topic: Connect to new router not sky
Message posted on 10 Oct 2025 05:16 PM
Using a new ee router and cant connect my mini box
Message posted on 10 Oct 2025 05:28 PM
Re: Connect to new router not sky
@Tony421 how are you trtying to connect your mini box ? As you have a third party router are you aware that you need to connect your mini box to your main q box and not the router if you are using wifi
Message posted on 11 Oct 2025 05:07 PM
My sky q main box is connected to my new btWiFi router but my mini box won't connect to my main box despite having gone through the settings to reactivate it
Message posted on 11 Oct 2025 05:16 PM - last edited: 11 Oct 2025 05:17 PM
@Ian346 wrote:My sky q main box is connected to my new btWiFi router but my mini box won't connect to my main box despite having gone through the settings to reactivate it
Hi @Ian346 How are things connected? For 3rd party broadband providers the Mini box connects to the Main Sky Q box (Sky Q Mesh), not your Bt WiFi. It should pick up the internet through the Main Sky Q box.
Message posted on 11 Oct 2025 06:10 PM
@Ian346 Have you tried rebooting your main Q box ie
then
reboot your mini box
you should be promptred to press the WPS button on your nearest piece of Sky Q equipment are you going to your main box and pressing the WPS button
