4
This discussion topic has been answered Discussion topic: Connect to new router not sky
This message was authored by: Tony421
Using a new ee router and cant connect my mini box
This message was authored by: Laing1 Answer
Re: Connect to new router not sky
@Tony421 how are you trtying to connect your mini box ? As you have a third party router are you aware that you need to connect your mini box to your main q box and not the router if you are using wifi
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Ian346
My sky q main box is connected to my new  btWiFi router but my mini box won't connect to my main box despite having gone through the settings to reactivate it
Hi @Ian346   How are things connected? For 3rd party broadband providers the Mini box connects to the Main Sky Q box (Sky Q Mesh), not your Bt WiFi. It should pick up the internet through the Main Sky Q box.
@Ian346  Have you tried rebooting your main Q box ie
then
reboot your mini box
you should be promptred to press the WPS button on your nearest piece of Sky Q equipment are you going to your main box and pressing the WPS button
Answered - Go to Answer
