Discussion topic: Connect Sky Q mini to hub
Message posted on 22 Sep 2023 09:03 AM
Hi guys,
I am about to order a sky Q box for an outbuilding we have, which is pretty far from the house. At the moment my main sky box is connected to the sky hub through wifi.
Will I be able to plug my Sky mini box via ethernet into the router? Will this work even though my main box is connected via wifi?
Message posted on 22 Sep 2023 09:08 AM
Re: Connect Sky Q mini to hub
@Goldman18 wrote:
Hi guys,
hi @Goldman18
it depends on who your router/wifi is with - if SKY yes this should work, if not SKY then no - in this case you need to connect the ethernet from the mini to the main box (or both to the router)
Message posted on 22 Sep 2023 09:12 AM
Hi @Goldman18 , short answer is no, the Sky Q mini receives it's content via the main Sky Q box and as you have this connected via WiFi then the only way to do this would be via a Sky booster , I don't even think power line adapters would work unless the 2 box's are on the same ring main.
Message posted on 22 Sep 2023 09:13 AM
Hi,
That is great, thank you. Yes I am with sky, had just read contrasting things over whether it will work with the main box using Wi-Fi.
Message posted on 22 Sep 2023 09:16 AM
Ok this is what I mean with contrasting answers!
Would it defintley work if my mini box is plugged into the main sky q box (regardless of how that is connected to the internet)
Message posted on 22 Sep 2023 09:24 AM
@Goldman18 wrote:Ok this is what I mean with contrasting answers!
If it were me I would hardwire the router to the main Sky Q box via an unmanaged switch then hardwire the mini box to the same same switch it that is possible.
Message posted on 22 Sep 2023 09:29 AM
@Goldman18 wrote:
Hi,
When your broadband/wifi is SKY you can mix & match connections & ethernet is the most reliable - especially for the outbuidling.
Message posted on 22 Sep 2023 09:30 AM
Hi @nigea99 , I take it from your reply that Sky Routers have WiFi backhaul then?
Message posted on 22 Sep 2023 03:33 PM
@kop32 The Sky router forms part of the Sky mesh where as with a third party broadband the router doesn't form part of the Sky mesh
Message posted on 08 Jan 2024 01:50 PM
Thanks both for your answers.
One more (stupid) quesiton. If i connected the sky mini box to a switch first and then to the router, would that still work the same? Or does it have to go directly from the mini box to the router?
It is just I would like something else connected in the outbuilding too.
Message posted on 08 Jan 2024 02:42 PM
hi @Goldman18
It should be OK to go via a Switch - but note SKY Q doesn't seem to like managed switches - OK with unmanaged ones
Message posted on 02 Dec 2024 10:25 AM
I have sky q, and have mini box and tv in the garden . Works fine as long as connected to the WiFi
