Discussion topic: Connect Sky Q mini to hub
This message was authored by: Goldman18
Hi guys,
I am about to order a sky Q box for an outbuilding we have, which is pretty far from the house. At the moment my main sky box is connected to the sky hub through wifi.
Will I be able to plug my Sky mini box via ethernet into the router? Will this work even though my main box is connected via wifi?
Re: Connect Sky Q mini to hub
@Goldman18 wrote:
Hi guys,
hi @Goldman18
it depends on who your router/wifi is with - if SKY yes this should work, if not SKY then no - in this case you need to connect the ethernet from the mini to the main box (or both to the router)
This message was authored by: kop32
Hi @Goldman18 , short answer is no, the Sky Q mini receives it's content via the main Sky Q box and as you have this connected via WiFi then the only way to do this would be via a Sky booster , I don't even think power line adapters would work unless the 2 box's are on the same ring main.
3 x Sky Stream (trying again) , VM 1 gb Broadband and Google Nest WiFi Pro.
Avatar for Goldman18
Hi,
That is great, thank you. Yes I am with sky, had just read contrasting things over whether it will work with the main box using Wi-Fi.
Ok this is what I mean with contrasting answers!
Would it defintley work if my mini box is plugged into the main sky q box (regardless of how that is connected to the internet)
If it were me I would hardwire the router to the main Sky Q box via an unmanaged switch then hardwire the mini box to the same same switch it that is possible.
@Goldman18 wrote:
Hi,
When your broadband/wifi is  SKY you can mix & match connections & ethernet is the most reliable - especially for the outbuidling.
Hi @nigea99 , I take it from your reply that Sky Routers have WiFi backhaul then?
@kop32 The Sky router forms part of the Sky mesh where as with a third party broadband the router doesn't form part of the Sky mesh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Thanks both for your answers.
One more (stupid) quesiton. If i connected the sky mini box to a switch first and then to the router, would that still work the same? Or does it have to go directly from the mini box to the router?
It is just I would like something else connected in the outbuilding too.
hi @Goldman18
It should be OK to go via a Switch - but note SKY Q doesn't seem to like managed switches - OK with unmanaged ones
This message was authored by: Bec73
I have sky q, and have mini box and tv in the garden .  Works fine as long as connected to the WiFi
