5
This discussion topic has been answered Discussion topic: Colour of indicator LED
Why did Sky not use bright Red to show that the box is off ?
Why on earth did they pick amber - this looks almost identical to green and makes it extremely hard to see whether the box  is on or off !
Protanomaly - is a colourblindness that reduces the shade of red by a degree - meaning that RED looks like AMBER  - and AMBER looks like YELLOW (which means that the difference between  yellow and pale green is hardly noticeable !!)
This should have been obvious at the design stage but was clearly not even considered !
This message was authored by: Skull+Treaty Answer
Re: Colour of indicator LED
@PandJ2020 wrote:
There's no colour when the box is off.
Perhaps @Anonymous was referring to standby (after pressing the power button on the remote) - which leaves an amber/orange light on the device.
That's how I read it anyway.
@Skull+Treaty wrote:
Perhaps @Anonymous was referring to standby (after pressing the on/off button on the remote) - which leaves an amber/orange light on the device.
@Anonymous Sky use red on the box as well for when the box goes in to eco mode if you have that set
so red is the box is in deep sleep mode
amber is standby
green is on
I believe red can also show if there is a problem with the box and it won't come on
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@Skull+Treaty that is what I meant yes
No thoughts at all on colourblindness
This message was authored by: cbball
You are lucky you can see any colour of light!
In daylight times, the indicator is so dim I cannot see any light at all.
Answered - Go to Answer
