Discussion topic: Channel pixelating
This message was authored by: Galway145
Channel pixelating
Hi , anyone else having serious trouble with watching virgin media 2 , channel keeps pixelating & keeps saying no satellite signal, . . . It's only just on that channel also
Re: Channel pixelating
@Galway145
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If it doesn’t you’ll need to contact Sky Ireland to book an engineer appointment.
It’s worth noting that:
