Discussion topic: No sky
Message posted on 15 Jul 2025 07:25 AM
No sky
Message posted on 15 Jul 2025 07:36 AM
Re: No sky
@Truckdriver123
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
