Discussion topic: Channel 777
This message was authored by: Andie3
Channel 777
My sky keeps switching to channel 777 on its own. It also turns the sound right up to a 100 and then down to zero
I have taken the batteries out of the remote and it still does it .
Re: Channel 777
Creepy.  Have you tried power cycling the main box?
Avatar for Andie3
Re: Channel 777
I have powered it completely off and back on twice. I have also turned of the TV at the mains but it's still doing it intermittently
Re: Channel 777
@Andie3 You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
