2
This discussion topic has been answered Discussion topic: Channel 5
This message was authored by: RTH
Channel 5
Can't get channel 5. All other channels OK but ch 5 is pixelated or frozen.
been like this for over a week.
Avatar for RTH
This message was authored by: RTH Answer
Re: Channel 5
Since diagnosed as a fault with the Sky Q box. Now replaced and problem solved.
Re: Channel 5
Hi @RTH
You may have a slight dish misalignment.
This may not necessarily affect all channels but just those with the weakest signal.
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
Avatar for RTH
Re: Channel 5
