Discussion topic: Engineer
This message was authored by: Dorascullion19
Engineer
Need a engineer as sky box not working properly
Re: Engineer
@Dorascullion19
In what way?
Avatar for Dorascullion19
Level 0 icon
Re: Engineer
It's being playing up,recordings freezing,picture disappearing at times,tried all the usual rebooting etc
Re: Engineer
@Dorascullion19
Try rebooting your broadband hub, then a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
This message was authored by: Navazehmad
Re: Engineer
Need a engineer
my sky Q box not working properly
Re: Engineer
@Navazehmad
Hi, you aren’t directly talking to Sky by posting here. If you are new to the forum then welcome to the Community which is made up of Sky customers helping other Sky customers with additional help from Superusers like myself.
In what way isn't it working properly?
