5
This discussion topic has been answered Discussion topic: Channel 5
This message was authored by: Caz+doggy
Channel 5
There are no programme listings for channel 5 from 6am Monday 3rd June until 6am Tuesday 4th June 2024. Why is this? I am not able to schedule any recordings, c5 +1 is the same.
Re: Channel 5
@Caz+doggy
It may be that Channel 5 haven't provided the data yet. You could try to refresh the epg by rebooting your box.
~ press the 🏠 button
Re: Channel 5
@Caz+doggy
Re: Channel 5
@Caz+doggy
It could be a fault (as I see the same) so it might be worth sending an email to the Viewer Relations team at Sky to let them know about this -  [email protected]
This message was authored by: stringy66
Re: Channel 5
i think the best thing to do is just speak to someone i will be not happy
Re: Channel 5
@stringy66
Are you having this issue (no C5 listings) NOW as I have listings for the week. This thread is now 6 months old.
Re: Channel 5
Just episode of a series channel 5 are looking into it aswell
