Discussion topic: Channel 140
Message posted on 13 Sep 2026 10:19 AM
Channel 140
When I pause a program on Channel 140 it will flick backwards and not start from where I paused it
Message posted on 13 Sep 2026 10:21 AM
Re: Channel 140
And Channel 240 froze completely today, had to unplug and reboot
Message posted on 13 Sep 2026 10:25 AM
Re: Channel 140
@Tinkertom wrote:When I pause a program on Channel 140 it will flick backwards and not start from where I paused it
I just tested this and cannot replicate the issue personally, does it happen on any other channels?
Usual starting place with any problems like this is a full power cycle which solves many issues. Simply unplug from the wall for a good 5 - 10 minutes before powering back on.
Message posted on 13 Sep 2026 10:26 AM - last edited: 13 Sep 2026 10:26 AM
Re: Channel 140
@Tinkertom wrote:And Channel 240 froze completely today, had to unplug and reboot
Well that answers that!
Go for a full power cycle and leave it unplugged for a while, it is more effective than a quick reboot.
Message posted on 13 Sep 2026 10:51 AM - last edited: 13 Sep 2026 10:53 AM
Re: Channel 140
I've noticed this with Discovery owned channels (including Quest) over recent months and there was another topic about it I replied to recently.
If you've been watching the channel for a while and then pause, rewind or fast forward it will sometimes jump back to when you started watching. It seems particualrly bad if the pause/rewind/fastforward involves an adbreak, so it is probably related to Sky Adsmart.
I've never had a full crash though.
Message posted on 13 Sep 2026 11:30 AM
Re: Channel 140
That is definitely what it does, very annoying!
Message posted on 13 Sep 2026 11:32 AM
Re: Channel 140
Maybe will try leaving it unplugged for a bit longer next time!
Message posted on 13 Sep 2026 11:51 PM
QUEST HD (Re: Channel 140)
Channel 140 is QUEST HD
Channel 240 is QUEST+1.
(For everyone who finds context helpful and names easier to understand than numbers only)
I do not have a sig other than this message. SkyQ.
Enjoying HDR with 4k Blu-Ray, Amazon, YouTube and gaming since 2016.
