Discussion topic: Changing
Message posted on 04 May 2024 09:11 AM
Changing
Sky Q very slow to respond. When changing channels the screen goes black but can hear audio. Eventually it changes channel. Also the home and recordings page are not displaying and pictures. I have rebooted and tried a sw upgrade.
Message posted on 04 May 2024 09:53 AM
Re: Changing
Hi @Mortis1975
