Discussion topic: Sky mini box does not work
Message posted on 04 May 2024 09:36 AM
Sky mini box does not work. Have tried to reboot. Internet signal is very good
Message posted on 04 May 2024 09:52 AM
Re: Sky mini box does not work
Reboot the mini as above.
