Discussion topic: Change of aerial
This message was authored by: Rupert+100
Change of aerial
I am moving from communal aerial to single.
i have followed your instructions but find the only option to communal aerial  - SCR
is Wideband.   Is this the same as single
NDR ?
   Many thanks.
Re: Change of aerial
Can you explain exactly what your doing?  Sky Q requires a dish and not an aerial.
If you're now using a different dish (?) it needs the appropriate LNB for Q.
Avatar for Rupert+100
Sorry, I mean a dish !     Also have changed LNB on single dish for Q box.
Who?  Sky?
This message was authored by: Godfrey
@Rupert+100  If I understand you correctly, you are attempting to use your own satellite dish, instead of the communal Integrated Reception System installation, to feed signals to your Sky Q receiver.
If this is the situation you will need to have a Wideband LNB fitted to this single satellite dish, with two coaxial cables installed between the Wideband LNB and your Sky Q receiver.
Then, you will need to change the LNB mode setting of your Sky Q receiver to use WIDEBAND LNB mode, before removing the mains power to your Sky Q receiver for around 30 seconds before restoring mains power to your Sky Q receiver in order to allow it to reconfigure itself to actually use Wideband LNB mode.
Godfrey.
Excellent, very many thanks. I have already fixed the new LNB ( at my caravan ) but it would not mate to the box.  I also seem to have a problem with resolution as it is a cheap and cheerful TV  ?
@Rupert+100 so from that I take it you are taking your Q box out of your home and to a caravan to use
If thats the case I'll just say that to do so is against Sky's T&C's where the viewing card must only be used at the address it is registered to just so you are aware
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
Thank you for your help.  Still not solved problem. It now seems resolution is the problem. My set at home is a high resolution set and it seems I must reduce same to mate to lower spec set i caravan.
Minimum you can set the box to (without being able to see the screen) is 1080i using the home-1-0-8-0-home remote sequence.
how cheap and cheerful are we talking?
Thank you, the TV is a  JVC cheapie with a resolution of c. 1080.
Can you clarify the "home" sequence to change the resolution.  My home set is LG Oled set at 2160 10 bit.
On the remote hit that sequence and the box will reset to 1080i
or just change it through the menu while at home.
@Rupert+100
Just to add to what @Chodley has advised
pressing Home 1 0 8 0 Home is designed to default the box to 1080i & is used to reset when for any reason a device is unable to display at a previous setting (i.e. can be used without needing to see an image)
Most TVs with an HDMI connection should be able to respond to a 1080i signal even if their native resolution is lower
Also as @Chodley says you can set it on your main TV before moving it (it will probably look awful at anything less than 1080)
Having said that,  I should re-iterate the reference to T&Cs  regarding location as mentioned by @Laing1
Thank you to both responders.
This is a one off as I want to watch The Masters on holiday.
The 12th won't quite look the same on your old Tv methinks 🙂
