Discussion topic: Chanel 5
Message posted on 14 Dec 2023 07:04 PM
Chanel 5
No signal for chanel 5 or anyother 5chnls everything else ok.
Anybodg else with same issue
Message posted on 14 Dec 2023 07:25 PM
Re: Chanel 5
Any error message on the screen when you try to view 105?
Message posted on 14 Dec 2023 07:50 PM
Re: Chanel 5
That no satalite signal its the same on all 5s bannels 5 action etc
Message posted on 14 Dec 2023 07:51 PM
Re: Chanel 5
@Lottiesimone
If a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. After that look at the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
Message posted on 14 Dec 2023 08:02 PM
Re: Chanel 5
Its only chanel 5 all other chanels work
Message posted on 14 Dec 2023 08:04 PM
Re: Chanel 5
That link still applies.
