Discussion topic: Chanel 5
This message was authored by: Lottiesimone
Chanel 5
No signal for chanel 5 or anyother 5chnls everything else ok.
Anybodg else with same issue
Re: Chanel 5
@Lottiesimone
Any error message on the screen when you try to view 105?
Avatar for Lottiesimone
Re: Chanel 5
That no satalite signal its the same on all 5s  bannels 5 action etc
Re: Chanel 5
@Lottiesimone
If a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. After that look at the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
Re: Chanel 5
Its only chanel 5 all other chanels work
Re: Chanel 5
@Lottiesimone
That link still applies.
