15
This discussion topic has been answered Discussion topic: Ch4
This message was authored by: CCC
Ch4
Why has Ch4 suddenly disappeared?
This message was authored by: ftballman Answer
Re: Ch4
Wow I'm amazed this thread has gone so long. England games on channel 4 are blocked in Ireland. They have been all through this rights deal.
Virgin media 3 have the game in blurry vision or if you know what you're doing, 1 of the other channel 4 regions can be manually tuned.
Re: Ch4
@CCC
It hasn't. I'm watching Ch4 now for the build up to the football.
Avatar for CCC
Re: Ch4
I have a message ' not available in your area' all other channels are fine.
This message was authored by: Invisiblename
Re: Ch4
@CCC  All working for me.  What "area" are you in?
I am just another Sky customer!
Avatar for CCC
Re: Ch4
Thanks for replying.  I'm in Dublin. I have SkyQ. On line help no use as recommended retune all channels or factory reset which will lose all recordings
Re: Ch4
Not sure what you mean by "retune all channels"? There is no "tuning" for satellite received channels, that sounds like advice for a TV
This message was authored by: vinny,
No channel 4 on irish sky
Is channel 4 not on sky anymore
Avatar for CCC
Re: Ch4
I know.  I mean reset the box and/or do a system reset as advised in Sky help. The error message is not recognised in the Sky app help.
Re: Ch4
@CCC
FYI another Irish customer has reported the same issue.
Re: No channel 4 on irish sky
@vinny,
Another Ireland customer has reported the same. I'll merge your posts.
Re: Ch4
hi @CCC
2 things :
1) Is it possible that it is just the Football match that is on that might have restrictive rights not allowing it to be shown in Ireland ?
2) If it is not restricted then have you tried just doing a full power down restart of your Q box ?
Re: Ch4
This message was authored by: Ryan37
Re: Ch4
Same thing in Ireland tonight, suddenly no access to CH4
Avatar for CCC
Re: Ch4
    Thanks for your replies👍
Re: Ch4
Same here, was back later
