Discussion topic: Certain channels BBC One WM HD no signal
Message posted on 11 Oct 2023 01:18 PM
Has anyone else had issues with no satellite signal with some channels like BBC One WM HD, Sky History HD? Started happening yesterday All other regional BBC One HD channels are fine No inclement weather locally
Have power cycled Sky Q & checked satellite cables with normal 90 quality 70 signal
Message posted on 11 Oct 2023 01:25 PM
Re: Certain channels BBC One WM HD no signal
@Mark+Lawrence+72
If it still displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. Just to make you aware, if you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
