80
This discussion topic has been answered Discussion topic: Cbeebies/ Cbbbc not broadcasting msg
This message was authored by: hitbox47
Woke up this morning to error message on 2 channels.
No programme is being broadcast, it flashes up for a millisecond then switches to the message.
Same with CBBC too.
I've tried a couple of reboots to no luck and tried the lines coming in from the dish , loosened them and put them back on fully tightened and still no luck.
Luckily we have quite Alot of kids stuff on recordings haha
Anyone else got the same error?
I know it's been pretty bad weather wise so I have an idea it's the satellite or LNB has been moved, signal is at 70% , strength is at 90%
This message was authored by: KevNewMedia Answer
Re: Cbeebies/ Cbbbc not broadcasting msg
Posted by a Sky employee
Hi Everyone
Thank you for your patience whilst we worked through this fault.
Our support teams have confirmed that the issue has been resolved. We're sorry for any inconvenience.
I'm going to mark this post as the current answer, so that everyone has the most up-to-date information.
Kev
Community Manager
This message was authored by: Chellwill
Yes we have the same message and issue.
This message was authored by: Douglas57
We have the same problem. Comes on for 1 second then goes off and shows message "No programmes are currently being broadcast on this channel. Slight panic for us as our grandson (2) is arriving soon for the day haha.
This message was authored by: Nikki862
Also have the same problem
all other channels seem to be working..
Do you think it's just a technical glitch or they gone forever?
my 3 year old isn't best pleased 😢
This message was authored by: Me280584
I have the same problem on the same channels, checked everything and rebooted
Avatar for hitbox47
Level 3 icon
Judging by the amount of other people are reporting the same thing, I'd go for a technical issue.
Problems might be with BBC sending it to Sky
This message was authored by: Em106
We're down in Hampshire and have got the same thing. However, we've got a freeview telly upstairs and it's broadcasting fine on that so wondering if it's an issue with Sky?
Currently having to watch milkshake on 5 but im wondering if there is other issues too as wont let me rewind/fast foward or pause either however record is working
This message was authored by: LisaB7
Yes the same thing here.
We use the programmes as a countdown in the morning. Breakfast with Bluey. Uniforms on whilst Peter Rabbit on. Teeth and hair by time number blocks on and then we leave when love monster appears!!
Today was fun 🤣🤣🤣
This message was authored by: Chomalungma
Yep, same 🤦‍♂️
There seems to  be lots of glitches on Sky this morning with this problem and pause/rewind issues on many channels.
Until the problem on Sky is fixed, if you go into iPlayer, select channels on the left, then choose CBBC or CBeebies and select Watch Live, you can watch the channels that way.
It would appear to be a problem with the SKY settings as I can receive CBBC HD on a non SKY Satellite box
SKY are aware
This message was authored by: Missmiller13
Omg life saver haha. This was really stressing me out haha
This message was authored by: mollie++edmunds
Same here!
This message was authored by: bethaniegeorgia
Mine is also not working! Watching it live via player instead 🙂
