This discussion topic has been answered Discussion topic: Cbeebies/ Cbbbc not broadcasting msg
Message posted on 16 Sep 2025 07:20 AM
Woke up this morning to error message on 2 channels.
No programme is being broadcast, it flashes up for a millisecond then switches to the message.
Same with CBBC too.
I've tried a couple of reboots to no luck and tried the lines coming in from the dish , loosened them and put them back on fully tightened and still no luck.
Luckily we have quite Alot of kids stuff on recordings haha
Anyone else got the same error?
I know it's been pretty bad weather wise so I have an idea it's the satellite or LNB has been moved, signal is at 70% , strength is at 90%
Message posted on 18 Sep 2025 10:29 AM
Hi Everyone
Thank you for your patience whilst we worked through this fault.
Our support teams have confirmed that the issue has been resolved. We're sorry for any inconvenience.
I'm going to mark this post as the current answer, so that everyone has the most up-to-date information.
Kev
Community Manager
Message posted on 16 Sep 2025 07:53 AM
Re: Cbeebies/ Cbbbc not broadcasting msg
Yes we have the same message and issue.
Message posted on 16 Sep 2025 08:05 AM
We have the same problem. Comes on for 1 second then goes off and shows message "No programmes are currently being broadcast on this channel. Slight panic for us as our grandson (2) is arriving soon for the day haha.
Message posted on 16 Sep 2025 08:24 AM
Also have the same problem
all other channels seem to be working..
Do you think it's just a technical glitch or they gone forever?
my 3 year old isn't best pleased 😢
I have the same problem on the same channels, checked everything and rebooted
Message posted on 16 Sep 2025 08:27 AM
Judging by the amount of other people are reporting the same thing, I'd go for a technical issue.
Problems might be with BBC sending it to Sky
Message posted on 16 Sep 2025 08:28 AM
We're down in Hampshire and have got the same thing. However, we've got a freeview telly upstairs and it's broadcasting fine on that so wondering if it's an issue with Sky?
Message posted on 16 Sep 2025 08:33 AM
Currently having to watch milkshake on 5 but im wondering if there is other issues too as wont let me rewind/fast foward or pause either however record is working
Message posted on 16 Sep 2025 08:41 AM
Yes the same thing here.
We use the programmes as a countdown in the morning. Breakfast with Bluey. Uniforms on whilst Peter Rabbit on. Teeth and hair by time number blocks on and then we leave when love monster appears!!
Today was fun 🤣🤣🤣
Message posted on 16 Sep 2025 08:43 AM
Yep, same 🤦♂️
Message posted on 16 Sep 2025 08:44 AM
There seems to be lots of glitches on Sky this morning with this problem and pause/rewind issues on many channels.
Until the problem on Sky is fixed, if you go into iPlayer, select channels on the left, then choose CBBC or CBeebies and select Watch Live, you can watch the channels that way.
Message posted on 16 Sep 2025 08:51 AM
It would appear to be a problem with the SKY settings as I can receive CBBC HD on a non SKY Satellite box
SKY are aware
Message posted on 16 Sep 2025 08:59 AM
Omg life saver haha. This was really stressing me out haha
Message posted on 16 Sep 2025 09:05 AM
Same here!
Message posted on 16 Sep 2025 09:06 AM
Mine is also not working! Watching it live via player instead 🙂
