Discussion topic: Cant use my sky mobile remote
This message was authored by: Danjonbrown
As my sky remote stopped working many months ago, I have to use my mobile to turn channels over. I for some reason can no longer connect to it and programs are not recording
Re: Cant use my sky mobile remote
@Danjonbrown
Why haven't you arranged for a new remote? If your Sky Q remote is definitely broken/faulty , if you follow this link it should allow you to do some troubleshooting and then send you to a form to request a replacement (this is not available for ROI customers).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
Otherwise you can purchase a new one from a lot of retailers / main supermarkets.
Avatar for Danjonbrown
I didn't think I needed to buy a new one as I could use my mobile instead
@Danjonbrown
As Sky Q equipment is loaned to you, if the remote is faulty Sky will replace it free of charge although it's sometimes quicker to buy one.
There is no app you can install on your mobile that will let you operate your Sky Q box.
