Discussion topic: Cant get connected
Message posted on 20 Oct 2023 05:14 PM
Cant get connected
I have changed my broadband provider today and tried to change my password on my skyQ box. Message on screen is saying no signal and I have tried trouble shooting and it's not working. My main sky box is working fine. Can you advise please?
Message posted on 20 Oct 2023 05:19 PM
Re: Cant get connected
Hi @Sandy13
If your main Sky box is working fine then I assume your issue is with a Mini box.
Reboot the mini as above.
