Discussion topic: Cannot pause live tv, rewind and recordings not happening
Message posted on 03 Jun 2023 09:10 AM
I can not pause live tv, when I try after about 5 seconds the screen goes blue with the message this channel has a technical fault. Happens on every channel. And my recordings aren't recording
Message posted on 03 Jun 2023 09:28 AM
Re: Cannot pause live tv, rewind and recordings not happening
Hi @MattV4
Have you tried rebooting your Q box.
Message posted on 05 Oct 2023 07:29 PM
I have this problem also. Have followed the advice above several time and still no success. Very frustrating. Please advise.
Message posted on 09 Oct 2023 08:43 PM
I have had to reset the Sky box every night because of this issue. It only solves it until the next time I press rewind etc then back to square one.
Is there a fix, or is my Sky Q box needing replaced?
Message posted on 09 Oct 2023 08:45 PM
I had to have a new main box to solve it sadly. 7 weeks I had until they fixed it. Still no refund due to lack of services in that time as well.
Message posted on 20 Oct 2023 12:02 PM
On all channels I cannot pause the TV. If I hit pause the screen goes black.
I also cannot play recordings . When I select a recording and hit play the screen goes blue.
Message posted on 20 Oct 2023 04:40 PM
@Karl59 Have you tried rebooting your main Q box ie
