Discussion topic: Cant connect BB to sky q box anymore.
Message posted on 20 Oct 2023 04:00 PM
Everything was working fine and now we can't connect the router to the sky q box (we only have one, no minis etc) We've tried everything an engineer has been out to do with the internet as sky noticed a fault but even he couldn't get it to work either?
Message posted on 20 Oct 2023 04:17 PM - last edited: 20 Oct 2023 04:20 PM
Re: Cant connect BB to sky q box anymore.
Hi @Jodie36
No chance you can connect your Q box to your router by Ethernet is there?
If not; Just to check.
First try rebooting the Q box.
Then carry out a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
If you cannot get it to connect you need to ask Sky for a Q WiFi booster to try between the router and the Q box. If you are not on Sky Broadband you would need to connect the Booster by a shortish Ethernet cable to your router.
