3
This discussion topic has been answered Discussion topic: Cannot connect to BT hib
This message was authored by: David6662
My Sky q box has lost its network connection but despite putting in the
 hub password it will not connect
This message was authored by: Quoman7 Answer
Re: Cannot connect to BT hib
Hi @David6662 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
This message was authored by: Greenfingers001
Avatar for David6662
Your advice was appreciated and worked- many thanks
