Discussion topic: Sky Q installation query?
Message posted on 28 May 2025 06:29 PM
I have ordered Sky Q and it is to be installed at a block of flats, I've had messages from Sky regarding the engineer needing access to the communal TV system, which there isn't as the other flats all have their own Sky dishes.
my question is does the engineer come pre armed with a dish or do they come with the assumption there's a shared dish and feed?
Thanks.
Message posted on 28 May 2025 06:32 PM
Re: Sky Q installation query?
If you're allowed to to have your own dish then the question is whether they can install it safely...
Message posted on 28 May 2025 06:38 PM
@PandJ2020 wrote:If you're allowed to to have your own dish then the question is whether they can install it safely...
Ground floor flat so no issues with access or height.
