This discussion topic has been answered Discussion topic: Cannot connect to BT hib
Message posted on 25 May 2025 09:40 AM
My Sky q box has lost its network connection but despite putting in the
hub password it will not connect
Message posted on 26 May 2025 09:17 AM
Hi @David6662 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
Message posted on 26 May 2025 09:12 AM
Re: Cannot connect to BT hib
Message posted on 28 May 2025 05:49 PM
Your advice was appreciated and worked- many thanks
