Discussion topic: Cannot change freeview channels using my sky q remote
Message posted on 12 Apr 2025 03:27 AM
With my old SKY remote if I wanted to control my freeview channels I would press the TV button and then i could change freeview channels. With my SKY Q remote all I can do is control the volume and the input source, I have to use my tv's original remote to change freeview channels. Does anybody know if there is a way to change freeview channels using my sky q remote or am I stuck using 2 remotes. Seems like SKY have taken a step backwards
Message posted on 12 Apr 2025 06:57 AM
Re: Cannot change freeview channels using my sky q remote
Don't think so.
I haven't had a TV aerial for about 15 years though.
Message posted on 12 Apr 2025 08:17 AM
Why not watch those channels via Q?
Message posted on 12 Apr 2025 09:30 AM
There are some channels that are only available on freeview. And the original sky remotes could control both the TV and sky. With the sky q remote it is not possible to search through freeview channels
Message posted on 12 Apr 2025 02:14 PM
Really? You have some examples? I didn't know that.
Message posted on 12 Apr 2025 02:17 PM
@SkunkZ unfortunately the Sky Q remote will not be able to do what the Sky + remote was able to do so afraid you will need to use the TV remote to control the freeview channels on your TV
All the Q remote will control as you say is sound and on most TV's input source
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 12 Apr 2025 02:18 PM
And power on/off
