Discussion topic: Mini Q box not connecting to wifi
This message was authored by: Kitchen2
Been away for 2mths. Sky box been on but TV off. On return main sky box and 1 bedroom box working. 3rd box displaying NO SIGNAL. CHECK THE EXTENDED INPUT OR SELECT ANOTHER INPUT.
Tried turning off at socket but still displaying error. Thanks
Re: Mini Q box not connecting to wifi
Hi @Kitchen2
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).  If you are on Sky Broadband with the new Sky Max router then you cannot connect minis to this.
@Kitchen2 that could be a message from your TV is the TV set to the correct hdmi input for the Q box try using your source button on the TV remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
