Discussion topic: Cancelling Sky Q
Message posted on 16 Feb 2024 06:38 PM
Cancelling Sky Q
I have recently cancelled Sky Q and was wondering do I need to log out apps on it like Netflix, Amazon Prime etc before it is sent back?
Message posted on 16 Feb 2024 06:39 PM
Re: Cancelling Sky Q
Shouldn't be required but I would recommend it.
Message posted on 16 Feb 2024 06:42 PM - last edited: 16 Feb 2024 08:04 PM
@CancelledSkyQ or You could reset the box to factory settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
scroll down to reset then pick factory reset
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 16 Feb 2024 06:51 PM
Tried, but doesn't do anything when pressed 001 ?
Message posted on 16 Feb 2024 06:57 PM
@CancelledSkyQ wrote:Tried, but doesn't do anything when pressed 001 ?
hover on settings. Hit 001 then select.
