Discussion topic: Netflix sky q
This message was authored by: Mcmc1
Netflix sky q
Hi - I get Netflix on 2 devices with sky q - I was wondering if it's possible that the 2 devices can be say a fire stick and iPad in the house and not tied to the sky q app on the sky q box? Does anyone know if that's possible to do? Can I sign up then log out of the app on the sky q box? TIA
Re: Netflix sky q
hi @Mcmc1
The limit is just current devices and & can be any device with the app - you don't need to log out of an app just not use it when using the other device(s)
BTW Although I only use one at a time I use it on my Tv's own app, Firesticck & Tablet rather than though  SKY Q (after it was set up via SKY Q).
Re: Netflix sky q
Yes, you can use it on anything. It's simultaneous devices (and location) they limit.
Re: Netflix sky q
@Chodley wrote:
Yes, you can use it kn antthibg. It's simultaneous devices (and location) they limit.
Re: Netflix sky q
@oldfella wrote:
I have no idea what you're referring to 😉
