Discussion topic: Can't control volume with sky remote
Message posted on 07 May 2023 01:59 PM
My new Cello tv doesn't come up with a code to connect to sky remote
Message posted on 07 May 2023 02:57 PM
Re: Can't control volume with sky remote
@JeannieL Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 10 May 2023 01:35 AM
Same no luck even when I entered in the tv model number manually.
Message posted on 10 May 2023 04:24 PM
@Olivetree3 try the vestel tv's as they make loads of TV's for different companies so trying the vestel codes may work
Message posted on 20 Dec 2024 07:47 PM
FYI, I bought a new Cello webos tv and tried to pair my SKY Q remote to it.
Took a lot of doing, but the answer was simple...it uses LG software, so...
Just use the first LG option
Home>Settings>Setup>Remote>Follow instructions>Type in LG>select Find it for me (the first option worked for me)
I can now control Volume, Source and Switch off TV and SKY box.
