Discussion topic: No satellite signal
This message was authored by: BMHharwood
No satellite signal
We lost satellite signal when we had scaffolding erected
we have now moved the dish so there is no obstruction but still have the same error message
how long does it take to pick up the signal ?
any other thoughts to correct the situation gratefully received
ben
Re: No satellite signal
This has nothing to do with Sky Go 😞
Which Sky System do you have?
1. Sky Plus (Sky Plus Forum)
2. Sky Q (Sky Q Forum)
I am Neurodivergent Sky+HD  LG NanoCell TV  Xbox Series X  Raspberry Pi 5 (Debian Linux)
My F•A•Qs: Sky GlassSky StreamSky GoSky Plus
Avatar for BMHharwood
Sky Q
I'll move this thread then
benn
Hi @BMHharwood
Looks like your dish is probably misaligned.
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
httpss:/wwww.sky.com/help/articles/skytvv-no-satellite-signal-sky-q
ben
You get a signal as  soon as the dish is aligned properly and cables connected without problems.
Who moved the dish & is there any reason why the signal at the box was not checked befre they left ?
The scaffolders asked if the sky box etc was working. Before they left and my wife said it was, .... but it wasn't
How do I know the exact position required for the dish.  Does it have to be very accurate or is the general direction ok ?
I have checked the cables and they all seem fine
Needs to accurate and aligned by a specialist @BMHharwood
hi @BMHharwood
The alignment is critical and cannot be done by the naked eye - it needs to be checked with a meter.
SKY will do it and generally charge around £65 but engineer appointments are very thin on the ground, so probably best to get a local installer to do this
Thank you.
I probably shouldn't have moved it in the first place !
