2
This discussion topic has been answered Discussion topic: Can anyone help? Our sky q minibox is wont switch on from standby?
This message was authored by: ChrisG4
This message was authored by: Laing1 Answer
Re: Can anyone help? Our sky q minibox is wont switch on from standby?
@ChrisG4 try pressing the on button on the front of the box. Where the amber light is showing is the on button if it comes on the Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for ChrisG4
Excellent, that's all sorted now, Thank you!
Answered - Go to Answer
