Discussion topic: Can I get my Q dish realigned for free?
This message was authored by: Wibbly-Woo
Scaffolders moved my dish
Can I get it realigned for free?
This message was authored by: Padam_Padam
Re: Can I get my Q dish realigned for free?
If you are having reception issues then you should be able to get an engineer out to re-align the dish.
You can book an engineer here:
https://www.sky.com/help/articles/book-engineer-sky-q
This message was authored by: bemak187
@Wibbly-Woo  Unlikely if it was moved by other tradesmen.  There will likely be a charge for sky coming out (all you can do is call and see) and the same if you used an independent.
@Wibbly-Woo
You'll need to call Sky but they usually charge around £65 … and then another £65 once the scaffolding is removed if the dish needs moving again.
@Padam_Padam
It won't be free.
@Padam_Padam
It won't be free.
They re-aligned my dish for free after our scaffolders whacked the dish during some exterior work a few years ago. Once the scaffolding was down I contacted Sky, an engineer came and did the re-alignment in a matter of minutes - no charge.
@Wibbly-Woo
I'll rephrase my reply. If the scaffolding is still up and the dish needs moving (if there is a suitable position) to get a satellite signal Sky will usually charge about £65.
Avatar for Wibbly-Woo
Level 4 icon
@Daniel0210
The dish doesn't need reinstalling - just pointing at the satellite - the scaffolders knocked it out of alignment and the signal is dodgy (BBC1 totally gone - others keep on breaking up)
@Wibbly-Woo
Give Sky a call to arrange an engineer.
This message was authored by: best+of+the+best
@Wibbly-Woo wrote:
@Daniel0210
If the scaffolders knocked it out of alignment then the scaffolders need to foot the bill for getting an engineer out to realign the satellite dish if asthe call out is not free.
As @Padam_Padam stated the scaffolding was removed before he called a Sky engineer so no evidence of it being whacked by a scaffolder then
