19
This discussion topic has been answered Discussion topic: CNN listing on the TV guide
This message was authored by: JamesMcG1978
CNN (ch 506) programme times offset
I seem to be experiencing an issue where the listing for CNN (channel 506) have the correct shows listed, but all at the wrong time. For example, a show that starts at midnight, is listed as starting six hours later at 6am. The show is actually aired at midnight. In order for me to record the correct shows, I need to select record on whatever show it thinks is airing at midnight. In short, I'm having to record by airtime and not by the listing. This also means that the series link doesn't work as it records when the guide thinks the show is on, which actually aired six hours prior and is now missed.
I have carried out a soft reset by unplugging my Sky Q box for at least 30 seconds. This did not resolve the issue.
Next, I carried out a reset of my settings. This did not resolve the issue.
Next I used the hidden menu and carried out a factory reset, wiping all settings & recordings. This did not resolve the issue either.
I'm not sure what to do now & would appreciate any assistance that anyone can advise?
Re: CNN (ch 506) programme times offset
@JamesMcG1978
I have moved your post into the thread already discussing CNN issues. Please see the post marked as the answer. Sky don't own or operate CNN.
Re: CNN listing on the TV guide
Thank you. It would appear to be an issue with CNN themselves. I'll just need to wait until they sort themselves out. Thank you for your response and for moving my question to the correct thread.
This message was authored by: AaronKing
CNN is wrong
My sky is saying the wrong listing on cnn
Re: CNN is wrong
@AaronKing
Answered - Go to Answer
