Discussion topic: Building work
This message was authored by: Joyful60
Building work
Unfortunately I ran my car into my house wall. The wires are still in tact but there is going to be a lot of building work, so my cable will need to be moved and extended.
the work will mean moving the outside cable, would this be done for free by Sky.
Or should I get private cables in to do the job.
Re: Building work
@Joyful60
Sky will likely charge you for such work, usually about £65 I believe. A local independent satellite company may be quicker but obviously get a quote first.
