Discussion topic: No satellite signal on tv but phones are connected to our broadband
Message posted on 31 Jul 2025 08:56 PM
No satelite signal on tv
Message posted on 31 Jul 2025 09:08 PM
Re: No satellite signal on tv but phones are connected to our broadband
@Peat1 A No Satellite TV mesage has nothing to do woth Broadband, what TV box do you have? Sky+HD or Sky Q
Message posted on 31 Jul 2025 09:22 PM
A no satellite signal could be damaged cables from the dish to the box, trees near by blocking the signal as I had last year and had to have my satellite dish moved because of a tree on the street in fall leaves was blocking the signal also if you have scaffolding up near or around the house that can block the signal to, to the dish, also check all the connections on the dish and the box and check the dish has not moved
Message posted on 01 Aug 2025 02:57 AM
@Peat1
If you’re seeing a “no satellite signal” message on a Sky Q set up check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
