Discussion topic: Buggy sky q and minis
Message posted on 18 Nov 2023 06:21 PM
My sky q box has been slow with changing channels and intemittently losing the tv guide. Now neither of the two mini boxes are working saying there is a technical fault with the channel despite it working on the main box (which is still running slow). Have reset all the boxes by switching off/on and done the same with the router but still not working. Any ideas what the problem is and how to fix?
Message posted on 18 Nov 2023 06:25 PM
Re: Buggy sky q and minis
Hi @Rs12345
First thing to try is a Reset Settings on the main Q box.
Reset Settings is in the Q box hidden menu.
